yamaha mariner 60hp cdi wiring 1983
tricky160
Hi all, I bought a boat with mariner 60hp motor, engine No. 6FO 302375 belive to be 1983 year. Was told needs new power pack (cdi). A boat wreckers sold me a TIA-02 but connections are different, mine bullet connectors. Does anyone have wiring diagram for this motor, any help appreaciated.
carholme
Re: yamaha mariner 60hp cdi wiring 1983
That s/n comes up as:
60 EL 6F0-301585 - 6F0-305060 1982 2-Cyl, Japan
From here:
Mariner 60-350 hp, produktions?rslista, modellguide
Parts Listing:
Mercury Parts, MARINER 60
See CDI unit, item 40 under IGNITION SYSTEM
Here is a link to the condensed version of the Clymer service manual. Download it soonest as the link is short lived.
Small Engine Repair Reference Center Home
The bullet connectors are no problem as you can always change them but as this is such an expensive part, can you say how much you paid for the one from the salvage yard and do you have a complete number, ie; T1A02-??
Gerry
tricky160
From here:
Parts Listing:
Gerry
Its a TIA-02 12 004 was $200au. thanks for the manual.
carholme
From this list if you select Ctrl and F you can type in the numbers 83030M and you will see that it brings up the CDI p/n: 117-TIA02-12
http://www.cdielectronics.com/downloads/CRPL.pdf
If you type in 98715M, the CDI p/n is: R6F0-85540-10-00.
As best I can find is that the 83030M is for the 60 hp engines with s/ns beginning with 675.
The 97815M is for the 60 hp engine with s/ns beginning with 6F0.
You could send a message to Faztbullet here on this site as he may know if they are compatible or contact CDI but at the moment, it seems that you have one for engines beginning with 675.
Gerry
tricky160
Gerry
I was thinking if i buy the stator that suites the TIA02-12, the wire colours will match up,
my stator has no blue or yellow wires, but has 2 green wires
tricky160
mine is a 60E not EL
98715M looks like the right CDI
the manual you linked to me is different
carholme
L just means a long shaft
If you look at the s/n list I sent you, you will see what that s/n brings up and it states that yours is a long shaft engine. Is it a long or short shaft.
As stated in my previous post 98715M is the right CDI for your original setup. However, you are now saying that you are going to use a T1A02-12 which is not the correct one for engines which begin with 6F0 as yours is. It is for engines which begin with 675. The reason I said to contact CDI is that I cannot confirm the compatibility.
As far as the manual goes, the 6F0 series engines were only available in 1982/3 so if that manual is not the correct one, I do not have another one.
Gerry
