Yamaha ignition switch or fuse???? HELP
jim0149
I have a F115 TLRD. When I turn the ignition switch on there is no power to the gauges and the motor does not start or turnover. Is there a fuse somewhere or has my ignition switch gone out?? I am getting power to the console because the horn, lights, live wells, ect. come on. Just nothing when I turn the switch on. Thanks in advance.Jim
eng241
Re: Yamaha ignition switch or fuse???? HELP
There are a set of fuses on the eng. with green and yellow covers. Check them . Also check to make sure your battery studs are tight.
jim0149
I have checked all fuse and ground connections with no luck. Any other ideas???
Jim
jim0149
eng241, you were right on the money. I had not checked the fuses on the engine, just under the console. The upper yellow 20 amp fuse was blown. It took out all guages, tilt & trim, and starter. Thanks again for the help.
Thanks,
Jim
eng241
No Problem, Glad I could help.
