Yamaha 90 hp cylinder re-lining ??
thebulldog
Anyone know if a 3 cylinder Yamaha 90 hp can be re lined with a cylinder tube ?
Tx in Advance
99yam40
Re: Yamaha 90 hp cylinder re-lining ??
Talk to your local machine shop and see what they say.
robert graham
Is your cylinder messed up to the point that it can't just be bored oversize and new piston? I believe the liners are cast in place rather than pressed in, but your Yamaha dealer might give some thoughts on this. Good luck!
rodbolt
check with a MARINE machinist, even cast in liners can be bored and resleeved.
Ron's marine and equipment in portsmouth VA does it all the time.
boatguy123
does anyone know what i should torque the cylinder head on a 2005 yamaha 50 fuel injected engine? I was thinking around 18 pounds? I dont have a shop manual.
99yam40
Start an new thread of your own. your question has nothing to do with that post you added it to. do a forum search for manuals and spend the money it will save you tons of time and money in the long run
