Yamaha 9.9FMH Service 2 stroke
dejv
what is needed to service this outboard? it will not be used till next summer
i purchased the impeller what else is needed ?
thanks.
pscrabber59
Re: Yamaha 9.9FMH Service 2 stroke
How bout new spark plugs, and change out the gear lube oil and you should be good to go
99yam40
You need to stabilize the fuel or drain it all out of the system if is to set up for long periods on time
connemaraisland
No the above will not do it, you will have trouble. With todays fuel you must run stablizer through it and I would drain the carb float bowl (usually a small screw on the bottom of the float bowl). Pull the plugs and put 6 drops of oil in and pullit over by hand 2-3 times. Change the gear oil. - Bob
irakli2011
Hi,
I have 15 FMH motor.
Please help with model year of this engine
Thanks
