Yamaha 4 Stroke Timing 25HP
markbholt00
2006 Yamaha 25 HP 4 stroke F25ESH
I installed the timing belt with woodriff key aligned with the clyinder and arrow aligned with arrow on the block. All line up in a straight line. Timing indicator is aligned at 0 degrees. Motor starts, idles, and runs good but gets hot pretty quick but is pumping water good. I thought the motor may be a little out of time. Is this motor to be timed at TDC at 0 RPM?
