Yamaha 30hp 92 compression question
I am looking at a 1992 30 hp 2 cylinder. I was wondering if 82 and 89 were decent compression numbers or not. Thanks.
JB
Re: Yamaha 30hp 92 compression question
Howdy, BCM.
Welcome to iboats. :)
Assuming you used a good gauge and correct procedure, those numbers are acceptable.
You might check your procedure against the one in the Engine FAQs Forum.
Ok, thank you.mthe person who did the test said it was an old compression guage and that he thought he could hear a leak.
Ldavidgrover
Warm the engine first, Use a good gauge and advance the throttle to wide open and retry and you will see the number increase
JB
Throttle position will make no measurable difference. That is a myth. At cranking speed the cylinder reaches ambient pressure via the exhaust ports.
Use the procedure explained in the Engine FAQs forum
99yam40
Sucking air through a closed throttle will take longer to get up to max pressure in my opinion and experiences, but a lot of my experience came from automotive and not the 2 strokes. But I still think it is better to at least get the throttle off of the closed idle stop
JB
That theory has been tested many times by many competent wrenches, 99yam40. No difference has been measured.
I invite you to test your theory.
