FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I know thats what I was thinkin, it just sounds really high pitched, like a speed bike. cause when i turn the throttle handle and im not even fully through throttle positions and it sounds ridiculously loud and revvs high, and starts to pop a bit. not really sure what it is
yeah it sounds fine in idle, but when i put it in forward and give it throttle, it gets really loud with only like 1/8 throttle. im afraid if I keep going up its gonna blow. the rpms seem super high
You shouldn't really put it in gear and rev it on the muffs. The motor needs an appropriate amount of back pressure to run properly. I would try running it on the open water before you make any adjustments to it.
do you understand we mean you need to have it on a boat
and in the water even if still strapped to the trailer
so that there is load on the motor when you put it in gear and raise the RPMs?
pilot/idle screws should be set at factory settings, if everything is cleaned properly it should run fine.
Also should have the link and sync settings done as manual states
