Yamaha 200 Rectifier
inventry
Batteries Not Charging-- Checked Ac Voltage From Source (called
A Lighting Coil ) At 600 Rpms--- 8 Vac Measured ; Don't Know If This
Is Proper Output. Checked Lighting Coil Resistance And Measured .5
Ohms. This Is Correct According To Manual. Did Resistance Measurements On Rectifier And It Failed Four Test; Suggest Rectifier Is Faultiy. Have Found Many Discrepancies In My Seloc
Manual So Far And Am Hesitant To Buy New Rectifier. Does Anyone
Have Any Suggestions ?
Ray Neudecker
Re: Yamaha 200 Rectifier
Everything says the rectifier is bad. Ohming the rectifier is basically the same for all motors and Seloc should hhave it right.
