wrong prop
78big10
iv got a 1985 mercruiser alpha1 on a 16' huricane deck boat has a 19 pitch ss prop doest do to bad the guy i bought it from says it will do better with a 17" pitch would this gain power or speed
darrklim2
Re: wrong prop
Generally speaking, a 17 pitch vs. a 19 pitch would give you a little less speed, more rpms, and a better hole shot(power). The actual amount of difference depends on your hull type and engine, load, etc. I am not the expert on these things I just know the general things that should change.
rndn
Re: wrong prop
Really can't provide an accurate answer without knowing the actual rpm's at wide open throttle(WOT), motor make, outdrive make, recommended WOT, and the current prop.
Silvertip
Honorary Supreme Mariner
Re: wrong prop
Less pitch = higher rpm, less speed, better hole shot
More pitch = lower rpm, more speed, less hole shot GENERALLY!!!
The situation exists however, where a 17P may do just the opposite. It may increase speed, keep the same or provide better hole shot, and raise RPM. This happens when a higher pitch prop has put the engine way off its power curve. In other words the engine cannot twist the higher pitch prop at its recommended wide open throttle rpm.
