Wrong gear ratio on outdrive
adogdrian
Alright, so I have had this issue since I bought the boat. I think I'm supposed to have a 1.32 gear ratio on my outdrive, what's on it now is a 1.98. SEI only goes down to a 1.47 and only warranty's their outdrives up to 300hp, I have 330hp 454. My question is it possible to prop around the SEI 1.47 gear ratio?
Ayuh,..... For Alphas, that's been yer Only choice for many years,.....
achris
More fish than mountain goat
..... My question is it possible to prop around the SEI 1.47 gear ratio?
If it's quite a large boat and not a light go-fast job, yes... So, what size boat?
Word of warning. Heavy boats demand huge torque, and it's that torque that make Alpha drives 'self-disassemble', which is why Merc don't offer an Alpha drive to big engines. If you prop it right and are VERY ginger with the throttle, it should last... Get heavy-handed, and you'll find out why there's no Alpha drive options with BBC....
Chris.........
adogdrian
Chris.........
Its a 23' Searay weekender,
Your boat is from the era where SeaRay and Mercruiser attempted a BBC in front of an Alpha. Usually the drive met a spectacular end that Chris calls self-disassembly. Fragment grenade is more appropriate
There really should be a Bravo drive behind the BBC
If you look, every once in a while you may find NOS 1.32 gear sets
However the 1.47 are the lowest found today.
A very ginger hand, ease out of the hole, and a rev limiter to cut the motor if the boat ever catches air are all required to keep an alpha alive behind 300+ hp
adogdrian
Ya, I looked into putting a Bravo on it, but its to expensive for how much the boat is worth. Thanks
