rolmops
- Feb 24, 2002
- 5,741
1984 rebuilt 3 liter 140 Mercruiser with EST Voyager ignition
After rebuilding, this engine runs fine and smooth but still does not want to go over 3200 rpm while pushing a 1984 Starcraft Islander with a 14.5x 19 prop when it is properly trimmed out.
Trying to find the problem,I discovered that the carburetor on the engine #1389-9564 is for 165 and 170hp engines. The carb that is supposed to be on these 140 engines is #1389-9350 or #1389-9562.
Can this wrong carburetor cause the low performance? If it does,should I replace it with a #1389-9350 or a #13899562?
Thank you for your advice and opinions,
Cornelis.
Cornelis.
