would you purchase a composite propeller
reece3223
For the second time this season my aluminum prop has been damaged both are in the shop. I am thinking of purchasing a composite piranha prop. The price is fair and the rep said if was not what I expected i could return and apply the balance towards another purchase. I guess I am looking for any one with first hand experience using this prop.
thanks in advance
steelespike
Re: pros VS cons of composite propeller
Boy I guess you should be more careful.No personal experience but there have
been a couple excellent performance reports here not sure of the prop size but replacement blades are something like $27.I think the flo torque is adjustable.I think they can break unexpectedly someone reported losing 4 baldes at once in hard accceration.The company made good.
As I understand it if you have trouble with soft contact stainless props are said to hold up better needing repair less often. Of course they cost more and more to repair.
reece3223
yep it was a expensive learning experience. thanks for the input
still looking for first hand knowledge of composite props
ghansen
Re: would you purchase a composite propeller
I had one on my 17' Glastron with a 4.3 ltr motor. Boat ran great and never had a problem with the prop.
strokeoluck
Might want to try doing a search on iboats for that Pirahna brand. I recall the overall tone of the comments was somewhat negative (can't recall why) - but look it up to double-check.
MikDee
Banned
I've got a 17" pitch 4 blade Comprop, and it works great! ;) But, I have no idea how a piranna works?
Check it out here: http://www.comprop.com/
