Jonathan Albritton
Thread starter- Joined
- Jun 22, 2012
- 22
I have an XRI EFI blackmax 150, I think its 1995 (S# 0G199866). I was having problems when I was above ~2000rpm where the motor would die for a split second then start back again. After some trouble shooting I think I have it narrowed down to the idle stabalizer. On the last trip out the motor died for a split second a couple of times, I then disconnected the white/black wire from the idle stabalizer and the motor ran the rest of the day with no problems. I have heard of removing the idle stabalizer, but I'm a little concerned on the timing of the motor. My questions are:
1) Can I just leave the white/black cable disconnected with no problems, or should the whole module be removed? What would be the downside of just disconnecting the white/black wire?
2) Does the timing need to be changed to a different spec with no idle stabalizer?
