Re: Worst of two evils 3.7
Man.. nothing's easy. :facepalm:
I think you should have kept these two threads you have going as one since your kind of on the same subject on both.
Hopefully yo can get the EM off the head with the "stud" (broken bolt) still in, and work on it with a long shaft exposed.
Try putting some nice thin oil, trans fluid, PB Blaster around the broken bolt and maybe it will work itself down to help soften things up.
If you can get the rest out without breaking, maybe you can slowly twist the EM to the left and right to break free whatever corrosion may be left on the bolt shaft. If you can get it to rotate on the broken bolt, keep it lubed up and it should come off.
Good Luck!!
