Woodbinekeith
Thread starter- Joined
- Sep 1, 2009
- 86
It has a metal tank about 40" x 24" X 8" high. Guessing it holds about 12-15 gals and probably original - 1977. It had been out on the water with previous owner about 6 weeks ago but don't know if he used the tank or a portable carry-on. At any rate, I do want do do something about the gas tank.
Tank looks good from outside, fittings seem to be o.k., was used with a 2 cycle mix-the fuel/oil and doesn't seem to have much gas in it. I'm going now with a Merc oil inject. It has 2" wood lathes screwed to whatever is underneath on both ends and fit over the metal edge of the tank to hold it in place. This looks like the only way it is secured.
I could pull the tank, check out all the fittings, and give it a good cleaning (a really good previous thread on this). Not sure if I would have to take the tank out to do this - but how does on know for sure it is clean if it isn't removed?
I could pull the tank and just send it off to boat heaven or sell it. Replacement would be a 25L carry on.
I could just leave the tank on board, drain it, and set a new carry-on right on the top as there is room to do this. Probably not a good idea but it would be the least problematic.
Any thoughts - maybe another option or two
