Ok, <br /><br />I have a 20' Bay Hawk with soft spots on the floor. It had old beat up carpet which I am in the process of removing. I am going to replace the floor, probably with epoxy and then paint the deck. I have a few questions:<br /><br />1) The glass has been under carpet for its entire life as I redo the floor I was thinking that I should also put a layer of epoxy over the rest of the boat. Up the gunwales, and the forward casting deck. This would give me the same surface everywhere to start painting. Just making sure this is the right approach. Thanks for ya'lls input. <br /><br />2) I know that you can not use mat with epoxy so how many layers and what weight of fiberglass should I use on the new floor?<br /><br />Here are some pics of the progress so far. <br /><br />
<br /><br />
<br /><br />Thank you for the help.
