knehdn
Thread starter- Joined
- May 7, 2008
- 133
Took the motor off. Wasn't too bad. I first checked specs on the weight - only 150lb., so it was an easy lift. Then had to grind off most of the 1/4-20 nuts and a couple bolt heads holding the rear corner plates and thru-transom fasteners. The transom doesn't look all that bad. The laminations still seem pretty tight. Couldn't push in an awl with ease. I think I'll just flip it inside out after I clean it up a bit. I might even give the whole thing a good coat of some wood preservative and some paint. Couldn't hurt I guess.
Now I do have a question about the ribs. Between using an air gun and a pressure washer, it took me forever to get all the debris out of them. I'm thinking I just may get a can of that spray foam insulation and give each rib a little squirt to cap off the open ends.
Has any one tried this?
Is this not a good idea?
Should I just leave them open and do a better job on the regular cleaning and maintenance than the last owner!
Here are a few photos, cuz we all luv photos.
