Wooden Boat transom rating
evinrude20
Hi all, I have a question regarding the transom of my wooden boat. Its a custom craft shelter top cruiser, 19' with a roof, closed bow. When it was built (57') it had an Evinrude 50, big twin I think? first on the lake that size. Back in the 90s, it got upgraded to a 84' Suzuki dt115, which moved the boat along nice. There is room for about 8 adults comfortably. I have to redo the transom, which i believe is just a couple sheets of 3/4" plywood attached the the frame,(fibreglass outside) the 115 I have is going by the wayside, and I have a Blackmax 135 (88') I can get for free from a relative. I looked and it seems to be about 30lbs heavier and of course the added 20hp. Is this going to be an issue for the boat? Im not an engineer, just want to make sure its not over doing it. Thanks!!
zool
Re: Wooden Boat transom rating
depending on the width of your beam, you may be ok
19 (length) x 6 (beam) = 114 x 2 = 228 - 90 = 138 hp for non tiller
thats just a simple rough estimate, not sure if it proves legality...
evinrude20
Thanks for the info, I will check the measurements! Is 90 a constant?
jbcurt00
Yes, 90 is a constant.
Hopefully this guide will help you calculate the maximum amount of H.P. your boat can be insured for.
- This is to only be used as a guide.
- You can round your final HP number to the closest multiple of 5. (31 HP would round to 30 HP. 33 HP would round to 35 HP)
Step One - Compute your Factor
A. Length of Boat x Transom Width (measure in feet: 14, 15.5,16, etc).
Step Two - Compare your factor to H.P. rating
A. 0-35 = 3 hp
B. 36-39 = 5 hp
C. 40-42 = 7.5 hp
D. 43-45 = 10 hp
E. 46-52 = 15 hp
Step Three - If your factor is over 52 (Choose only A or B)
A. With Remote Steering (steering wheel) and at least 20" transom height
Maximum HP = (Your factor x 2) - 90
Example: 19' 6" long , 7 feet wide = (19.5 x 7 x 2) - 90 = 183 (Round up in multiples of 5. This boat's max is 185 hp).
B. With Tiller Steering (hand or extension) or less than 20" transom height (Choose only 1 or 2)
1. Flat bottom, or hard chined boats (hull has hard angles)
Max HP = (Your factor x 0.5) - 15
2. Soft chine, rounded hulls
Max HP = (Your factor x 0.8) - 25
