Wood stove install
tphoyt
Thx for the tour Joe. Nice spread ya got there.
How about some long eye hooks to hold the windows open. Quick simple and cheap.
redneck joe
i have them, it was on my radar but thinking want to do something more 'odd' to fit my personality better.
redneck joe
cut a couple vents down low (screened). Going to make some sort of movable cover to close off if I want to. The place is pretty air tight except for the windows and that is next up on the list. The second one is at the other end. Have 4" round vents for the upper.
redneck joe
pipe has about an inch of 'slack' in two of the connection points so next summer i can put the tile in
FLATHEAD
That will do a fine job heating your shed. Back in the day I had a small coal stove similar to that, it was a pot belly. I heated a 15 x20 wood frame garage with that thing. It would cook you out in the winter. I burned wood and coal in it. The install was a code violation from floor to top of flue. The flue went out the gable. I had a damper in the flue
flashback
You're gonna need an app to schedule your arrival so its warmed up when you get there or leave it at a slow burn.
redneck joe
Get one of those dual fans you set on the stove that run off heat to circulate the heat.
saw one of them at TSC and it was over $100!!!
i will be setting the place up for a solar panel and all 12v systems - just like a boat.
