Wood stove install
Mc Tool
My friend has this set up and he uses cheaper corrugated iron sheet ( we call it Zincalume , nice and shiny but pita coz you cant solder it to make custom fittings ) for the heat shield on the wall ....looks good too
tphoyt
I only used 45’s because the stove is centered in the room under the peak. The 45’s are together and spin on the band to any angle you want. I have no problem with cleaning. I use fiberglass rods that go through with ease.
And this even met code. But that was almost 30 years ago.
redneck joe
I dunno so much about log burners , but when I was running the show I had two gas fitters installing gas fires and one thing I learnt is that you cant take to much heat out of the flue otherwise the flow aint so good ....the exhaust being cooler . Im pretty sure the more heat lost out of the flue the more it will need cleaned ....I dunno how youd clean around 45 deg bends . You would just about have to dismantle it
the whips appear to be flexible enough to make the bend.
redneck joe
i could, just wanted minimal exterior pipe. Looks better imo and the double wall **** is pricey - plus would prob need support like guy wires - again, aesthetics.
flashback
If ya don't like the looks of a pipe thru the roof build a chimney box for the pipe to go through.
Mc Tool
My flue is straight , supported just above the ceiling and just below the roof on the inside . Flue is single 5" to the ceiling and then triple tubed thru the ceiling cavity ( air gap fed from ceiling cavity ) and the double tubed to the cap on the outside . The bit sticking out of the roof is about 2m high and has no support wires so I reckon if you support your flue before it goes thru the roof it should be ok .......but we dont get hurricanes or tornados here :D
redneck joe
if we have tornado that will rip off a chimney i got bigger issues to deal with...
Is the above the roof a solid stick of pipe?
Mc Tool
The inner most flue is one piece from the top of the burner to the cap , 6" seamless stainless steel , I know I previously said 5" but I just measured it ....def 6"
edit , actually thats not true ....there is one join about half a meter below the ceiling :rolleyes::)
tphoyt
It could be one pice. They come in many different lengths. The spark arrester would be separate but it has a pretty sturdy band clamp.
dingbat
Zincalume is an aluminum (55%) zinc (45%) coated steel trade marked by BlueScope Steel.
Galvalume is basically the same coating patented by Bethlehem Steel
Jeff J
A piece of light log chain will fall through a 45. Rattle it around a bit and most of the chucks will fall out.
I have responded to chimney fires that had the pipe glowing and had the surrounding structure smoldering. Fastest way to extinguish a chimney fire is to throw a wet rag on the fire (assuming there is good fire in the stove or fireplace). The steam will extinguish the fire. We did respond to one that started while the fireplace was being lit. No choice but to get on the roof and run water down the chimney.
Dad used to just let it burn out when I was a kid but we had a good brick chimney that was tall enough to not be too concerned about the roof. Sounded like a jet engine when it caught. Quite the show against a night sky.
Mc Tool
I have a 5kg cylinder of Co2 with a bit of hose on it , never used it on a fire but it doubles as a spare welding cyl and we used it to stop Haydens leyland tractor running away .
redneck joe
here is where i want it (yes move shelf) but the collar i got is 38" and thru the roof ppe is 48" so need to think more. If i put there the 8" drop leaved about 2 feet of pipe needed but would be ugly as hell.
redneck joe
and the shed is all done except the window and door trim/frames.
Note, the bell is installed...
Mc Tool
I just gotta say .... I dont see anything ugly about a bit of flue , its part of the whole pot belly burner thing ......as long as it doesnt look like its on the ****. I thought the idea of a rough cast iron burner was supposed to be a bit "rustic" . One of my friends fitted a log burner with a stainless flue and he rubbed the flue down with methalated spirits as the flue heated for the 1st time and it went all nice shades of blue , purple and brown ....looked real good .:):)
tphoyt
It will need to be a distance from the wall.
Might want to check your local code.
redneck joe
i have and will be doing additional work with cement board and aluminum tube. This is just placement atm.
