Re: Wood floor
Gee, I think gluing up smaller pieces would be a bad idea, as you will need to use waterproof glue, and you will have all those seams that can come apart. I would bet the floor would fail, even if you use a plate joiner. Use some dry 1/2" plywood and seal all edges with poly resin and put a couple layers of cloth over the plywood.
