Won't turn over!!!!
CPTom21
So I just bought my first boat(1964 Starcraft). It has a late 60's Evinrude 40hp. The gas can that was sold with the boat had some old fuel in it(it had to be at least 3 years old). My Dad decided to try and start it with the old fuel instead of just letting me take my brand new tank, fill it up, and use that fuel. It started up, but sounded very rough, and turned off after about 10 seconds. It would not start after that. I now have the new tank with new fuel hooked up, and it just won't turn over. Should I just keep trying to turn it on, or is there something else I should do. Any advice would be greatly appreciated!! Thanks.
-Tom
nwcove
Re: Won't turn over!!!!
it wont turn over?.....or it turns over but wont make a kick to start? need more info.
CPTom21
It starts, but won't stay on when you let go of the key.
nwcove
check the "big three".... compression, spark and fuel. it sounds like you have some of each ingredient, but do you have enough of each. do the checks for compression first, then spark, fuel air mix is a carb rebuild.
nwcove
.....also try starting it off the pull cord.....just to see if behaves the same ....or will even start. post back with your findings.
dirtdog38
if you hold the key will it stay running and when u let go does it act like you turned it off if so it might be a swich
Silvertip
Honorary Supreme Mariner
Geez -- get the old fuel out of it.
CatfishMN
He did say he hooked it up to the new tank and fuel. I'd say if the tank had 3 year old + gas in it, it is pretty likely the carb had gas sitting in it for 3 + years, so maybe a good place to start. Of course, check for spark and compression as well.
CPTom21
Thanks guys. I'm going out now to work on it. I'll try using the pull cord.
CPTom21
Yeah. If this is a problem where should I look/What should I do??
AlTn
old fuel is still in the fuel lines and carb unless you've drained them and forced fresh fuel in by pumping the primer bulb
lifeboat
I would say that the fuel, spark, and compression have been elimanated being it does start and run UNTILL he let's go of the IGN. SWITCH. I would replace IT (the ign. switch) first.
nwcove
if you unplug the keyswitch wireing, will those motors then start off the rope? ( electrical is a bit of a mystery to me!)
