wont turn over at times
agaldamez
When i try to start my boat it does nothing. I continue to turn the key and I hear the engine to try to turn over a few seconds, I stop and try again nothing, keep trying and it finally turns over and starts.
I shut it off and it seems to start easier once I get I get it going.
what could be the problem?
Fun Times
Re: wont turn over at times
Hi there, Is there any chance you could take a lengthy video of your engine starting procedure/troubles to help gain an idea of what's actually happening?
If you can, Have the engine hatch open and try to show what's going on at the helm area with things like the gauges, key, throttle handle, and finally the engine.:)
makonnen
The start of any diagnosis is to understand the systems invovled and check the easy simple stuff first before diving in deeper. Here's what I would do in the order I would do it:
1.
Check for loose connection, corrosion at the battery terminals ... tighten anyways
2.
Check for loose connection, corrosion at the starter slave solenoid located near the throttle body / carb usually - tighten anyways
3.
Check for loose connection, corrosion at the start solenoid
4.
Check engine ground
5.
Check, remove, clean, brush, sand all connections at battery, engine ground
6.
Put a voltmeter across the battery. The battery should read 12.4 - 12.8volts BEFOER the engine is cranked. Then have someone crank the engine, the voltage should drop to 11.X volts or so. If the voltage drops BELOW 10V ... you have a weak battery. So in that case, is the battery bad? Charging system not charging? If the battery volts DOES NOT drop, or drops too little and the starter did not actuate ... check the starter slave solenoid operation, check the starter solenoid operation ... give the starter solenoid at the starter a tap while cranking.
7.
Time to dig deeper. If voltage drop is correct, starter is actuating but motor is still not turning over ... uh-oh. Remve accessory belt and hope that an accessory is holding it back - not likely.
8.
If that doesn't help - it likely won't - pull spark plugs, check for water in cylinders.
1.
2.
3.
4.
Check engine ground
5.
6.
7.
8.
Ayuh,... Agreed,... I'm thinkin' the Answer is somewhere in 1 through 6,...
agaldamez
First of thanks for the help. After the advice here and also using the following document with a meter. Its come down to a bad starter. I removed it and got it tested and its bad.
My question is what brand should i use.
Mercury mercruiser
Sierra
Arco
Mallory.
Does anyone have a opinion.
Thanks
  • Troubleshooting a mercruiser Starting system rev3.pdf
stonyloam
Since nothing happens (no click), probably either the ignition switch, the Y/R wire going to the slave solenoid or the solenoid. With the voltmeter on the terminal of the slave solenoid with the r/y wire, see if there is any voltage when you turn the key to start. No= bad switch, wire or connection at switch. Yes= bad connection at slave terminal or bad slave solenoid.
achris
More fish than mountain goat
first of thanks for the help. After the advice here and also using the following document with a meter. Its come down to a bad starter. I removed it and got it tested and its bad.
Mercury mercruiser 1st, 2nd, 3rd and 4th choice
sierra 6th choice
arco 5th choice
mallory. very very last choice
does anyone have a opinion.
Thanks
hth
makonnen
Just make sure its not the starter slave solenoid located near the throttle body. I had the exact symptoms and it turned out to be the starter slave sol and not the starter solenoid or starter.
I agree with achris, Mercruiser would be my first choice by a longshot.
NHGuy
Also the OE Mercruiser can be rebuilt over and over and over...
agaldamez
Thanks for the help, all the help on the sight is amazing!!! Its running yessss!!!!
