Javelin379T
Thread starter- Joined
- May 15, 2017
- 5
I have a 1995 Johnson Fast Strike 150 on a Javelin 379T. Took out this weekend and noticed while running, once the engine is level and I trim up to reach higher rpms/throw a rooster tail it won't trim back down when I need to come to a stop. Once I back down and get to an idle the motor then trims down. What do you think is causing this, low hydraulic fluid or maybe the trim motor is going bad?
Thanks in advance
Thanks in advance
