wont start
timmyt66
i have a newley rebuilt 470 mercruiser engine that i can not get to start i have fuel i have spark to the plugs and from the coil but it just wont catch i have the number 1 piston up both number 1 valves are open and the rootor is pointing at number 1 on the distributor cap what am i doing wrong?
D
DJ
Guest
Re: wont start
Sounds like the ignition 180 degrees off. Both valves should be closed when the plug fires.
timmyt66
Re: wont start
i checked the timing and still have the same thing no fire only got 1 little burb through carb
Don S
Re: wont start
How about the points? They could be glazed over and only firing occasionally or real weak.
timmyt66
Re: wont start
PROBLEM SOLVED thanks for all the input on all my post... now lets go fishing
Don S
Re: wont start
Don't just leave us hanging, what was the problem????????????
