Re: Wont start no fire and no fuel
Tested the pickup coil does not short to ground fron F or G terminals and reading fron F to G is 792. Also checked the ignition coil and the reading from B terminal to ground was open, but the reading from B to C reads .5 that is above the .35-.45 spec but the reading from ground to high tension lead is 7650 is that telling me that the ignition coil is bad? Thank You for any input
