vwbugman69
- Jul 11, 2011
- 116
Title says it all.
I added a water separating filter and changed the ceramic filter in the fuel pump and now it will not start since it is not getting fuel. I put fuel into the filter, but that did not make a difference. I also tried adding fuel directly into the carb, but as soon as it fired up it would quit.
My first thought is I have an air leak somewhere, or the pump just can't generate enough head to pull from the tank.
I had to add approx. 7 ft of fuel line to mount it on the transom. Is this too much? Yes, I did change the gasket when I changed the fuel filter and there is only 1 installed.
