Won't shut off??FIXED!!!!
jerryjerry05
My neighbor has a boat with an older 110 evinrude E110tlcca.
It HAD a newer E88tsleoc. That's the wiring harnes that's in the boat.
The 110 hooked up to the wiring harness. But won't shut off.
Any idea what I can do to rewire or fix it.?
Anyone have a harness cheap?
He wants to sell it but can't untill it shuts off.
THANKS,Jerry
Joe Reeves
Re: Won't shut off??
Check it out (below) with an ohm meter.
(Ignition Kill Circuit)
(J. Reeves)
A Black wire (ground) should lead from the powerhead to the powerpack. There will also be a Black/Yellow wire leading from the powerpack to a raised "M" terminal of the ignition switch. To complete the circuit, there will be a Black wire from the other "M" terminal of the ignition switch to ground.
When the key is in the OFF position = The two "M" terminals are connected,. effectively shorting/killing the ignition.
When the key in ON position = The two "M" terminals are not connected and the ignition is engaged.
emdsapmgr
The wiring harness/control boxes were the same up through the 1995 model year, which was the year of the 88. Joe's got some good comments.
Joe Reeves
Jerry.... Why are you bumping? More problems?
jerryjerry05
Went away from the job for a while and was hoping more got added.
I finnaly have the boat in my yard and I can actually do something with it.
Thanks for the answers,I'm gonna go look now.
Been to Maxrules for the wiring diagrams. Got one for the 1988 88-110 Evinrude 110 E110TLCCA
This is the motor on the boat now.It runs but won't shut off.
The 95/88 is the one I took off and replaced with the older motor(blew the cylinder)
Need one for a 1995 Evinrude E88TSLEOC Maxrules has a bunch but not that one.
Any ideas where I can get one?
Will also need the key switch diagram for both motors.
Thanks,Jerry
jerryjerry05
Need more !!! I need the keyswitch wiring diagrams for both years 88/110 and the 95/88 along with the diagrams for the 95 E-88tsloc
Thanks,Jerry
jerryjerry05
Need wiring diagrams see #7 and 8 Thanks
jerryjerry05
FIXED!! Turns out there was a wire broken in the harness at the plug.
Took a while to track it down but it's working now.
