moneylargan89
Thread starter- Joined
- Jun 15, 2021
- 9
Recently bought a 1989 Bayliner Capri 1750 with Ford OMC 2.3l. So, first time taking the boat to the lake it started right up and everything seemed fine except for the boat seemed to struggled going into gears at first but after forcibly pushing the controlling stick and playing with the trigger it eventually went into forward but after maybe around 3-4 minutes the boat started overheating so I shut it down. The next day after doing research on this forum, I decided to change the water pump/impeller located in the stern and overheating was solved.
Now I'm still having issues with shifting. The control stick will only throttle forward and backwards when in neutral. but when the trigger is pressed and boat not in neutral the stick is stuck and will not go into reverse nor forward. the engine just rev but the prop don't budge. I thought I found the problem when upon expecting the engine area, I noticed the control cable that goes from the control stick to the shifting mechanism was severely damaged and was tapped off from previous owner but after replacing that cable with a new one the problem still persist.
I tried disconnecting the other red shifting cable from the shift bracket to see if I would be able to pull or tug on it but it seems stuck just as the control cable did but I can't see any visible damage. Is there a way to diagnose the lower cable without having to take down the stern? also is there a way to put the boat in gear manually? thanks
