Nutron
Thread starter- Joined
- Jul 10, 2011
- 73
I just got my boat yesterday and took it out on the water today. I had the old 90hp engine removed and put a 115hp on my 88 Glastron. No sooner than we got up to speed on the water the transmission cut out and the engine reved to full max. I right away put it in neutral and still the motor was reving high. I turned it of and restarted and it seemed to drop a little but not much. When I tried forward it felt in the gear shift like it was grinding, when I tried reverse the same happened.. Also there is no power, the max I could get is 2000 rpm's before all of this happened and it maybe did 20 tops. Any suggestions? I finally had to be towed back in, I tried looking at the shift linkage and could not figure it out. The motor is a 1975 Johnson 115hp motor, If there is any suggestions I would appreciate it, Maybe take it back to the marine and have them fix it, after all I paid 750.00 to swap out and they kept my old motor with a bad cylinder and the Power tilt and trim. I thought this was a good deal until I had to be towed back in.
