jambet12000
Thread starter- Joined
- Sep 26, 2012
- 3
Great Forum! I have searched the electrical forum and got close to the answer I am searching for but not quite. I am replacing the two rusted steel fuel tanks on my 1975 Starcraft Islander, one of which was disconnected. The new setup is this. The Two tanks feed to the back of the boat where a solenoid selects which tank to feed from. The sender on each tank is connected to a switch which has four terminals (1,2,3,4) which I assume feeds the selected tank's sender to the gauge. Terminal 1 goes to the gauge. In one position of the 2 position switch terminals 1&2 and 1&4 are connected. In the other position 1&2 and 1&3 are connected. I can't figure this out. What I would like to do is have one switch that would not only switch the senders to the gauge but also provide the 12v to the solenoid so that the gauge is reading the tank feeding the engine. Unfortunately, I am not the sharpest hook in the tackle box so would appreciate it if anyone could help me out with a wd and the type of switch that would do the trick.
