Wiring issues 1989 Bayliner Capri
dumbguy
1989 Bayliner Capri.
Switch bank on right of steering column works sometimes and randomly switch from what is working to something else.
Has any one a wiring diagram or suggestions?
Thank you.
Larry
NYBo
Re: Wiring issues 1989 Bayliner Capri
Welcome to iboats!:cool:
After 22 years, I imagine the connections at the switches have become loose and/or corroded. You'll have to remove the panel to you address this. Remove one wire at a time, and clean the terminals and slightly squeeze any of the loose crimp connectors on the part that holds it to the switch terminal. Also verify that the wires are tight in the crimp connectors.
kenmyfam
Wow, So there is a Bayliner section !!!:D
Larry is a good friend of mine and the issue appeared to be the switches themselves. So far, so good I think but I will let Larry write the official report.
