Wiring Harness
Arkman
I have an older mercury with an electric start. I'm trying to figure out what wiring harness I need but for some reason all I can find are the internal ones or a different style then I have for the external. I found this site the one in the middle (414-3369) is the arrangement i need but the part numbers listed only refer to internal harnesses. Does anyone know what external harness I need?
Thanks!
Re: Wiring Harness
The very bottom entry on the link you sent has the external (boat) harness. Is that what you need?
Arkman
Re: Wiring Harness
Um, well. Maybe. If I google that part number it comes back with an image of the harness that the pins are sort of reversed. If you look at the two big pins relative to the direction of the wire coming out it is opposite what I need. I'm sure it works, it just will be sort of backwards. i just thought there might be another harness that is set up for that layout.
Thanks for the feedback!
