wiring diagrams for ignition switch to fuse box...?
stoudt21
i just recently bought an 88 force 125hp and i have the power cable hooked up to the motor and to the ignition switch, but i cant seem to figure out how to get power to the switch from my fuse box. is there a wiring diagram that i get that would show me how to wire it to the fuse box?
WillyBWright
Re: wiring diagrams for ignition switch to fuse box...?
The boat systems are separate from the engine systems. The circuit breaker on the port side. Your public library might have a manual you can check out. Here's a parts diagram. The circuit breaker is #38...
stoudt21
ive got that part hooked up its going from my ignition switch to the fuse box underneath my dash board is where i am having problems. what wires do i need to send to the fuse box to give it power. but that diagram will probably come in handy for me later on though. thanks for that.
WillyBWright
The fuse box under the dash uses separate wires that also attach at the battery. Not thick cables, just 12ga or 14ga red and black wires. They keep boat systems separate from motor systems because if something goes haywire with a boat system, the motor will still operate independently. That and the motor fusing is designed for the motor alone and adding a bunch of accessories can easily overload it.
If you don't have those separate wires to the battery, you should put some in. You should also put an inline 20 amp fuse for the red wire back at the battery. Each fuse in the block should have fuses of appropriate amperage for the particular use. Generally 2-3 amps for electronics and 5 amps for lights and pumps. 10 or 15 amps for cigarette lighter/accessory plugs.
stoudt21
thanks alot i will try that im not sure how it is all wired up under there but i do know that there is a fuse back at the battery. also wich wire am i suppose to run to the fuse box from the ignition switch? am i suppose to ground it to?
