Wiring Diagram 2001 Crownline 266 BR
xXTECHxMANXx
Looking to see if anyone would have a wiring diagram for a 2001 Crownline 266 BR with a MX 6.2 MPI BIII tring to track down a fuel pump wiring issue.
alldodge
Welcome
Moving you to Merc section do to fuel pump problem
What is the issue?
tpenfield
Use the engine’s wiring diagram. the boat specific wiring is often not published
xXTECHxMANXx
I cant seem to find any wiring diagrams im trying to track down the fuel pump circuit to see what is causing it not to turn on
alldodge
Got that on the first post, but without knowing what "motor" your working on we cannot help
I'm pretty sure its not a Briggs and Stratton but other then that I have no clue. Might be a Merc, VP, Ilmor, carb, efi, mpi :unsure:
xXTECHxMANXx
It's a 6.2 mx is what the first post said that's what it says on the warranty registration
jbcurt00
Service manual is listed:
Has wiring diagrams for motor
alldodge
Sorry, I mixed yours up with another
Don't know if it has a MEFI, 555 ECM or PCM but... if I had a serial number ...
The fuel pump is turned ON/OFF by the ECM applying a ground to one side of the relay coil. Trun key ON, energizes Main Power Relay (MPR) should hear a beep then fuel pump turns ON.
If it's not turning ON then check fuses, MPR relay, FP relay and then wire from ECM
Her is 555
tpenfield
2001 vintage 6.2 would probably be either MEFI-3 or the ECM. The service manual for the engine is what's needed and it will have the wiring diagrams.
To clarify for the OP . . . Engine wiring is not boat brand specific, they all use the same wiring based on the motor.
