levittownnick
Thread starter- Joined
- Jul 2, 2003
- 789
My daughter is in the process of having an attached garage built. The common wall requires a fire rated 5/8" sheetrock. The circuit breaker panel is in the living space side of this wall so the wall will have wiring through it. I would like to put a small sub-pannel in the garage on this wall about opposite the main panel.
The big questions.
1) What is the minimum capacity sub-panel that can be used?
2) If the wall is pierced with conduit, can THHN be run through this conduit?
3) Is a fire rated sub-panel required? Is there such a thing as a fire rated panel?
4) What else do I have to know? (All outlets will be GFCI protected.)
5) Must I use AFCIs?
The big questions.
