wiring advice leisure battery
billywhizz
can anybody advise me how to correctly connect my leisure battery to the charging circuit, i have mercruiser 485 engine, the main battery shows 14.6 volts across the terminals with the engine running, when i do the same test on the leisure battery it reads 12 volts and runs down, the leisure battery is brand new and if i disconnect the live terminal and test between it and ground with the engine running only reads 7.6 volts?
Barnacle_Bill
Re: wiring advice leisure battery
How is the battery wired? In parallel with the main battery? Thru a switch? etc
billywhizz
the battery is wired through an isolator switch to the voltage regulator, i do have the mercruiser manual but it only refers to the main engine battery
Boatin Bob
Is this "isolator switch" a manually operated 4 position battery switch that says 1, 2, both and off? If so then do you ever run it at the "both" position?
Boatin Bob
I just saw you other post...why do you start 2 posts with the exact same question?????
billywhizz
No it is a single stage isolator, both batterys have one, i run the engine with both on, i thought i had incorrectly placed the post so did it again, now have two not sure how to delete post?:confused:
