Winterizing Water Sytems
Shaun78
Wheres the how to guide on this. sinks, hot water, toilets etc?
Scaaty
Re: Winterizing Water Sytems
Depends on your boat..owners manual will explain, ..if not..use common sense
pgdignan
Winterize the same way you would for an rv. Use the non-toxic antifreeze in the tanks and run it through the system, you can also pour some vegetable oil into the toilet to keep the parts from getting stuck.
