JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,763
Hi, I have a pulled engine (Merc 350 Mag sitting on a stand in my garage) that I need to winterize. I have run Stabilized gas thru it and sprayed fogging oil into it the last time it was run before I pulled it. The engine is going to be on the stand all winter while I do a transom replacement, and I've drained the water from the block and the exhaust manifolds. I'd like to change the oil as well, but everything I've seen suggest the engine should be run to warm the oil before draining. Running the engine really isn't an option, so I'm wondering if I'm better off draining the (cold) oil as best I can via the drain plug, or if I should wait until the engine is reinstalled and can be run, and then change the oil. Sorry if this is a simple question, but this is my first boat and first time to do any of this.
Thanks,
Jim
Thanks,
Jim
