Winterize now!
chiefalen
Ok ran the boat all is good.
Side note one stikin fish, weakfish 17"
Weather man just said under 30's tonight.
Draining my engine and manifold right after i post this.
I posted this cause i don't want to start reading about all the frozen cracked motors on boats that the guys who didn't drain there motors.
ziggy
Re: Winterize now!
sounds like the thing to do to me.
i've drained mine twice so far this fall. both times it only got close to freezing. but better safe than sorry.....
NelsonQ
Re: Winterize now!
I have an outboard but sadly enough, its that time of year. We're in for 29-30 degrees overnight tonight but they're calling for mid 70s for Fri/Sat/Sun
Don S
Re: Winterize now!
Let's not confuse things, that is not "Winterizing" that's just draining the block and manifolds so it doesn't freeze. This is Winterizing.
THE BEEF
Re: Winterize now!
Thanks for the tip,Im going fishing in the morning.
Lake Erie
Beef Creek Marina
BEEF
chiefalen
Re: Winterize now!
Don s of course is right, i should have said drain the block and manifold now!
The oil and all the other goodies i do on the last lay up. I ain't taking no freekin chance that my motor freezes.
tarheelebbtide
Re: Winterize now!
Thank God I have at least another month, maybe two before I have to worry about that!
bigbob_FTW
Re: Winterize now!
Don't have to do that till sometime in Dec or Jan. here. :D
Re: Winterize now!
Hey Chief, The Belmar, NJ forcast calls for mid 40's tonight. I would be surprized if the Manalapan forcast was for a hard freeze.
Well, draining the manifld and block is goog practice. I presume you trailer your boat? If not, the water is still 60+ and will keep the motor fom freezing.
