winterization
zgbgwfs1
I have a 4.3 liter cobra omc that i am trying to winterize. the manual says there should be two petcocks on the starboard side one for the manifold and one for the block but I am only able to find the one for the manifold. the one for the block doesn't seem to be there. the manual is accurate for the port side. any ideas?
Don S
Re: winterization
Keep looking, it's there, all Chevy 4.3 engines have a drain plug on the starboard side, it's not an OMC thing.
Here is a picture on a Mercruiser engine.
attachment.php
Dakota47
Re: winterization
There is 4 drain plugs on your motor, plus powersteering cooler. the manifolds each have one and the engine block has 2 on each side down low.
Gary H NC
Re: winterization
The ones on the exhaust manifolds are under the edge between the spark plugs.It will be brass pipe thread plugs or petcocks.
Be sure to poke a wire in the holes once you take the plugs out.Rust can clog them up.
Unhook the hoses at the thermostat housing and engine water pump,drain and put back on.
