Winter storage 35 HP
pikefisherman
I am in south west Michigan the pontoon rides are about to end for the season ,Question I ran out the fuel from motor and drained and changed the lower end oil, is their any other steps I need to take? The boat is out side with a tarp over motor and boat.35 HP 2 cycle motor 1993 Model.
Sea Rider
Re: Winter storage 35 HP
Does it snows or it's prettty cold out there at your location ? If not, why winterize. Run engine at idle on muffs for 5-10 minutes every month when off season. While fushing disconnect engine fuel connector till engine drops dead...
Happy Boating
You could spray some fogging oil into carb throat and spark plug holes. Turn motor over by hand to distribute oil. Reinstall spark plugs. Pump grease into fittings.
bonz_d
As long as it's covered and not going to get snow, ice or furry vermin in it and as long as it's stored in the down position so the lower unit doen't collect water and ice I wouldn't worry too much about it. Pull the batteries so they don't freeze.
WIMUSKY
Happy Boating
It gets plenty cold were pikefisherman resides.......
pikefisherman
We have been lucky the last few years not it the -20s like some years, but you never know around here. Thanks.
