sogood
Thread starter- Joined
- May 11, 2016
- 361
Hi guys. Looking for any information or help in my search for window trim. I'm refurbing a 1990 Wellcraft Sportsman 250 and need to replace the old window trim, as much of the existing trim is either broken or damaged. My online searches led me to Taylormade systems, as I was led to believe that they were the original suppliers to Wellcraft. I emailed them with my query along with some illustrations of the existing trim that I want to replace. They were most helpful and responded the same day with an attachment, showing the trims that I need, and stated that these trims were supplied by a company called "American Marine"
This company was subsequently taken over by "Aluminium 2000" which in turn became part of "Pompanette".
I sent the same query to Pompanette and to date am still awaiting a response.
So, in the meantime I thought I'd put it out here and see if any of you guys are familiar with these trims and where I might source them, especially as all of the above companies are/were based in the U.S. and I'm over here in Ireland where boat parts suppliers are limited and are mostly "main stream".
I've enclosed a copy of the attachment sent to me by Taylor made and the two trims in question are part numbers 30-1075 and 30-1021. Failing that, perhaps there is some sort of generic aftermarket alternative?
FWIW I've tried most of the trim suppliers online and I doubt if there are any that I haven't checked out already, but I'm wide open to suggestions. I've also included drawings of how these seals work in my current set up. The locking strip shown in the illustration isn't critical, but would be nice! having said that, I can work around this. Thanks in advance.
PS. Just discovered that the original document from taylormade won't upload, so my drawing will have to suffice for now. Still working on it.
