Will This Flywheel Work
redfish10
Looking for a used flywheel for my 1999 30Hp JOhnson 2 cylinder Model #J30ELEEC. I have a located a used one with a part number of 583001 and a casting number of 583002. Does anybody know if this will work or the part numbers of the the flywheel that will. Thanks.
mav6759
Re: Will This Flywheel Work
Good evening,
Let me check my part book for you and I can give you the part numbers if that will help.
Mav6759
tashasdaddy
according to ishopmarine the brp part was 585158, superceeded to 583001, so it should work.
mav6759
My book is showing me for a 30 hp Johnson J30ElEEC the part number for the flywheel assy is 0585158. If you can tell me what motor the new flywheel came off I can check the part numbers and let you know.
Mav6759
