Will Old Timers Formula work well on T-111 siding?
kjdunne
I'm building a backyard shed and will use T-111 sheets for the siding.
Will Old Timers Formula work? If yes, how long can I expect it to last? I'm just looking for alternatives to paint.
This will be in southern New Jersey.
Thanks, Kal
It will work for a few years. But I would seriously look at paint
Spar varnish is UV resistant, its one thing on a transom that sees sunlight ever so often vs a shed. I would suggest a UV stable exterior stain if you don't want paint. Remember to recoat every few years
Chris1956
Honorary Supreme Mariner
T-111 in my experience will suck up oil-based stain real well and last a decade or more. I would use some good oil based stain, like Cabot or Thompsons, if you can get it here in NJ. The modified oil base stuff from Cabot is nearly as good as the full oil, and real easy to clean up.
flashback
I built a shed about 20 years ago using t111 and put olympic stain on it, 2 coats initially and another about 8 years later. It still looks pretty good except for the bottom edges of the side that is close to the ground, its rotting a bit in places. I was trying to keep it low so I could get my bike in and out.
dingbat
Only product I’ve used in forever.
Allow to weather for a year and apply a second coat.
Remember to seal your cuts and ends of the siding prior to assembly to increase life expectancy
kjdunne
Thanks everybody!
I'll look into good quality stains.
jlh3rd
+1 on flashback comment.
My T-111 shed kit assembled in 1996 is still in excellent condition….except…the bottom edges sucked up water dripping off and had rot, even though it was inches off the ground.
What to do…didn’t wanna pull all the siding.
So I cut off 3” evenly all the way around, used pressure treated 1x3 as trim replacement, and made double sure the t-111 bottom edges were painted well.
redneck joe
seal the edges.
redoing mine at the new house and thats where the issues are, including the verticals so caulk your butt joints.
I've done about 3/4 of the 10x16 shed in board and batton and am bout 30 tubes of caulk in.
redneck joe
water penetrates. Like adding fans under my boat cover, why not have the extra layer of protection - like an additional bilge pump.
Chris1956
Well, T-111 is supposed to look like vertical T&G boards. Caulking the seams ruins that.
Even batten board siding would look better than caulked T-111, IMO.
Jeff J
I put fiber cement board sheets on a house. It looked like T-111. No lap joint so I caulked the seams and installed battens over them. I thought it looked good.
I quit using products with “caulk” in the name after that job. Silicone, latex, doesn’t matter. They all shrink and leak. If it needs sealed it gets silicone sealant. The builders of our new house used caulking at the wall penetrations. They had nice, clean looking beads around the conduits but they cracked and leak so I will have to fix it.
redneck joe
they are buying the cheapest tubes, that is why. Silicone is not paintable. House penetrations and hidden under batton ok but on a painted shed i want to paint it.
The cheap DAP tubes are $6. The ultra is $10 and that type of consumable accidentally makes it home with workers often so contractors go cheap.
Chris1956
Jeff, if you have 15# builders felt (tar paper) under the cement board at the seams, the caulk or battens at the seams is superfluous.
Jeff J
Fiber cement sheets were attached directly to the studs (a contractor buddy’s recommendation). I just redid the whole house again last year. Used zip system sheathing under metal with the idea I wouldn’t have do it again as long as I live. Looks a 1,000 times better and much more efficient for the heating and cooling.
Ended up not having to worry about doing it again anyway. I was about 3/4 done when the wife convinced me we should move.
redneck joe
i was supposed to die at our last house so i did everything accordingly. We moved this spring to a 1970's house that needed a lot of work. Almost done but if she wants to move again she sure can. Without me.
