Will my aerator drain my battery?
jackrabbit66
I'm trying to decide whether I should spend the $35 to get a timer switch for my aerator. Currently I have an on / off toggle switch and when I'm fishing with the motor off I'm worried about running down the battery. About how long would it take to run down a battery to a point where i couldn't crank the outboard motor if i ran the aerator constantly? The aerator is 1.8 amp @ 13.3 volts new and the battery has 685 Cold Cranking Amps but also states "mins. at 23 amps = 140". any advice or personal experiences regarding this matter are appreciated.
Silvertip
Honorary Supreme Mariner
Your aerator is electric therefore it draws power from the battery so yes it can run down the battery -- at some point. However, if it was left on constantly drawing 1.8 amps (let's use 2.0 for simplicity) we can run some numbers. Your battery states 140 minutes with a 23 amp draw. Since the aerator is only drawing 1/10th of that test spec (23 amps) the aerator could run for 1140 minutes (19 hours) before depleting the battery -- and it would indeed be depleted, as in stone dead. So to ensure the starting battery has enough reserve to start the engine, you could likely run the aerator for a full 8 hour day provided the engine is properly tuned and you know how to start it without cranking for long periods, A live well timer is a good addition whether you need it or not. Some have adjustable on/off times but the cheaper units are fixed and run for about 30 seconds and are off for 3 minutes. They have a manual position that allows constant operation if needed. In your case installing a timer should ease any fears about killing the starting battery -- provided the battery is in good shape.
