will a prop from a 1967 110 hp mercruiser fit on a 1985 Alpha 1 mercruiser?
S smithrock Petty Officer 1st Class Joined Jun 11, 2007 Messages 399 Aug 2, 2008 #1 will a prop from a 1967 110 hp mercruiser fit on a 1985 Alpha 1 mercruiser?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,375 Aug 4, 2008 #2 Re: will it fit? Ayuh,... It should...
S smithrock Petty Officer 1st Class Joined Jun 11, 2007 Messages 399 Aug 4, 2008 #3 Re: will it fit? As long as it has the same amount of splines, right?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,375 Aug 5, 2008 #4 Re: will it fit? Ayuh,... As far as I know,... Merc has Always used the same shaft size,+ spline count.... It should fit....
