bstone81
Administrator
- Sep 23, 2011
- 44
I have two 2001 Polaris Genesis Waverunners. Fuel Injected. First time out this year. They bogged down, and now will only idle but not accelerate at all. I think it interesting that it has happened to both. Thinking bad gas.
Here's what I have done to trouble-shoot. I have checked the fuel line pressure. Both are at 20 psi. Even pulled the fuel pump housing on one to inspect, and everything looked fine. Fuel pumps are working. Filters are clean. Air filter is clean. Put in new spark plugs. Throttle cable is working fine. Thinking it was bad gas and clogged the injectors, I put some seafoam in the gas, as well as took off the fuel line and poured seafoam direct into the fuel line. Still just idling, but not accelerating.
So I'm stumped. Is there an electrical module that regulates throttle increase for the injectors?
Any help will be appreciated.
