will batteries work?
bluedreamin
I just purchased a 14ft double wide and have money tied up in the trailer and nightime running lights and such, I have 4 250watt lights from home depot, I tried wiring them to a battery and the bulbs just turned orange but no light. the battery is not 100% if it is fully charged should this work? what do you guys with experience do?
skargo
Banned
Re: will batteries work?
What is a double wide? 250 watt lights? Are the metal halide or something? What are you working on?
mciaio
Umm... yeah... sounds like your are trying to run 110 volt lights off a 12 v battery. No, it won't work.
arks
You gotta use 12 volt lighting!
Pasted from Wikipedia. I highlighted the important part.....
"A fishing light attractor is a fishing aid which uses lights attached to structure above water or suspended underwater to attract both fish and members of their food chain to specific areas in order to harvest them."
"The perfect fishing light would have the following properties: 1) high intensity, 2) emit its light in a color similar to the fishes space (blue or green), 3) be powered by a portable electrical supply and 4) be submersible. The last attribute is desirable because significant amounts of light energy from land- or boat-mounted lights are lost by reflection off the surface of the water. No one commercial light satisfies all of these criteria."
Types
"Fishing lights fall into two groups: those that are portable and those that are permanently mounted. Generally, portable lights are powered by batteries and this sets practical limits to the kind of light that can be used. Most portable light sources are relatively low in light intensity and have short operating times. Lights drawing more than a few tens of watts are not practical. The old classic, a 12 volt automobile incandescent headlight mounted on a Styrofoam float ring, is probably the least expensive and lasts for a few hours before the battery is discharged. Battery-operated fluorescent lamps are three times more efficient in converting electricity to light. Therefore, comparing lamps of similar brightness, they can be operated about three times longer before the battery is discharged. Also, the lifetime of fluorescent lights are about ten times longer than incandescent lights. Commercial portable fishing lights based on fluorescent lamps vary widely in intensity. The best use 25-40 watt lamps that emit about 1000?3000 lumens per tube."
madgadget
Even if it did work you'd have a hard time running 1Kw of lights from a battery, that would kill a 110ah battery in an hour or less, it wouldn't do it good long term either.
seabob4
I'm going to keep an eye on this one...
Can I watch too? A we talking about a double wide house on wheels by chance? Hope he doesn't try to make a house boat out of it!
Can I watch too? A we talking about a double wide house on wheels by chance? And if it is, what in tarnation are you doing in a boating forum? Hope he doesn't try to make a house boat out of it! If these are 115 volt lights, batteries will work but you need 10 of them in series to make 120 volts.
seabob4
Damn, I hate when the OP disappears, I wanted to hear what a double-wide was...:confused:
Ayuh,... Especially considering a 14' housetrailer is only a Single-wide...
skargo
Banned
I know some houseboats are 14' wide, possibly that's what he has? :confused:
