Re: will a 74 exchange with a 79 115hp
Any V4 crossflow that has the cast-in lower front pan mounts is a direct bolt on for your mid section and all the internals, especially the crank, will enterchange. If the front lower pan mounts (with the rubber insert) are bolted on, it's earlier than 79.
It can have the flat or bubbled exhaust plates, that makes no difference.
